Unable to open temp clipboard file C:\Users\xxxx\AppData\Local\Temp\rh$9513.tmp
Disk full?
Nope. Plenty of space in the SSD.
When I press Ctrl+C it gives the following message:
“Unable to open temp clipboard file C:\Users\Waddah\AppData\Local\Temp\rh$7659.tmp”
no matter what, I can’t get it to work properly. I opened other files and the same message.
Only when I start a new file from scratch it works fine for a little bit, then it goes back to the same message!
So you are saying that you are able to use ctrl+c for a while before it starts happening? And for a file you already have created before, if you open it the copy/paste mechanism doesn’t work at all from the opening moment?
Do you have any AV or other security software running?
Yeah … deactivated a malware protection software that was somehow installed on my system. Now Rhino is working fine.
Thank you Nathan.
nathanletwory
Nathan ‘jesterKing’ Letwory
McNeel
December 24
waddah:
You probably could whitelist Rhino in the software so you can have it otherwise turned on, but still use Rhino.
