Ctrl-Backspace Not Recognized - New Rhino 8 Win11 Installation
Having finally bit the bullet and migrated over to a new machine after an increasingly intolerable frequency of crashes with Rhino fragmenting the workflow - am mostly back to speed now, but encountering a couple of minor things that seem awry.
One strange/unexpected thing is Ctrl-Backspace no longer registers in the command line for instantly wiping out a whole-word at a time. Making typos interminably tedious - wonder if this is a known variation effect of the OS implementation? (the combo works normally in other system applications)
System Info
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 95GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5080 (NVidia) Memory: 16GB, Driver date: 6-11-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.62
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port 0
  • Secondary monitor attached to adapter port 1
Secondary graphics devices.
Intel(R) Graphics (Intel) Memory: 2GB, Driver date: 6-25-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-11-2026
Driver Version: 32.0.16.1062
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\export_STL.rhp “STL Export”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
The Control Backspace does not work in 8. But, what version and platform did you used to use that key combination on? I am not sure why it changed, but I might be able to do some research.
Hi Scott, yeah - seeing that too, now I’m feeling a little crazy because it seems like it doesn’t work in 8 anywhere - but my muscle memory tells me I used to use it … a possibly confounding factor is I’ve switched two things - am now on Win11, maybe it worked differently in a Win10/v8 combo or back in v7?
In any event - thanks for checking in on it and if it never worked it’s a feature request from a parallel universe!
