CTD when trying to open Grasshopper directly from Revit Interface
Hello there, I noticed that in some Revit versions (2021 in this case)
CTD happens when you try to directly opening Grasshopper from the UI.
Everything is fine when you open through the Rhino interface, a little strange.
Here’s the bug report.
I also have the Crash dump but it’s too big for that forum.
Let me know
RhinoDotNetCrash.txt (2.6 KB)
Can you provide your rhino systemInfo as well as the Revit About info? Thanks
Does this happen with no other Revit Addins loaded? If so we will need to look at Grasshopper Addins after.
[Window Title]
Rhino.Inside - About
[Main Instruction]
Rhino.Inside© for Revit
[Content]
Rhino.Inside Revit: 1.26.9083.18516 (2024-11-13T10:17:12)
[Expanded Information]
Rhino: 8.11.24254.15001 (Rhino 8)
Revit: 2021.2 (21.1.70.21)
CLR: 4.0.30319.42000 (4.8.9282.0)
OS: Microsoft Windows NT 10.0.19045.0
[V] See details [Web site] [Read license] [See source code] [OK]
[Footer]
Press CTRL+C to copy this information to Clipboard
Hi @thomas.lagarde,
In the crash you sent it looks like is crashing a Grasshopper plugin called ‘Tunny’.
Apparently looking for the resources. May it be that your Revit is on a language different than English and this Plugin does not support that??
Just guessing here, but maybe the developer of Tunny has more info about this.
Oh really ? Thanks, I’ll uninstall it and see
Yup it was Tunny, I removed it for the time being.
Hi, @thomas.lagarde
Sorry for the inconvenience. I am the developer of Tunny.
I have looked at the information in RhinoDotNetCrash.txt and it does indeed seem to be a Tunny problem.
I don’t have Revit, so I didn’t target it for debugging, but I’ve seen several similar reports recently, so I’ll consider taking action.
Thanks for the report, I’ll look into it.
