CSV File can't be read by GH in file path
Issue still persists in most recent update, with same error VBNC_CRASH in Rhino Console and There is no valid parser available on the GH Read File node:
Rhino 7 SR9 2021-8-10
(Rhino 7, 7.9.21222.15002, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
Has anyone else found a solution? I’ve tested and confirmed the issue on two separate MacBook Pros, so it doesn’t seem like something that can be fixed by a clean re-install.
Hi Jim -
I see from the report (RH-36840) that the fix went in on August 13. You are running a version from August 10. The Rhino 7.10 release candidate that is available should have that fix.
Other than that, simply renaming Rhino 7 to something that doesn’t contain spaces and then running it should also solve it. I always unpack the app on the desktop and rename it to “7.x.xxx”, which is why I wasn’t able to reproduce the issue on my system.
still solves the problem in 2023 =) thank you
