Cset Tree Structure Problems
I have made a set of points created from intersections. I need to group and sort these points by their X coordinate, and connect them together using lines so I can loft them.
I have attempted to use CSet and MIndex to group the points with the same index, but it runs into problems with 2 or more distinct branches. The second branch loft correctly, but the first one seems to group the first set x coordinate in the first list, but uses the second branch x coordinates after. Have I set the structure correctly?
pipe weave path help.gh (26.9 KB)
Edit: keeping the two branches separate:
pipe weave path help_re2.gh (11.8 KB)
This should do it, no? do you need the two branches separated?
pipe weave path help_re.gh (11.5 KB)
Thank you so much! I needed those branches separated.
This should work as long as the points were sorted in the proper x y z vector.
