Crowd Control for easy patterning
Hi All,
I’d like you to meet a new plugin of mine which is available via the PackageManager command in Rhino 9 (in Beta now). Search for ‘CrowdControl’ or my name to find and install. See the video at the end of this post for a 10 min intro to get started. Enjoy!
How it works: Fill a region, a surface or a whole object with copies of an object from your own library.
Pick what to fill — a closed planar curve, a curve drawn on a surface, or a whole SubD, polysurface or mesh. Choose a pattern: a hex, grid or brick lattice, or an even scatter. Then choose how it meets the shape — laid flat and projected on, wrapped over the curvature with spacing measured across the surface, or following the object’s own texture mapping, whether an unwrap or a planar or box mapping.
Everything re-arranges the crowd in place, from panel fields or from draggable handles in the viewport: spacing, stagger, scale, depth, rotation, and how strictly the lattice is obeyed. Members can be kept clear of the edge, sized to the room they have, and grown or shrunk by their distance from points and curves you nominate as attractors. Deform to surface replaces the copies with geometry wrapped onto the shape, the way FlowAlongSrf and Squish do.
Copies are block instances, so dense fills stay fast and files stay small, and each crowd is stored in the document — so it stays selectable and re-tunable after a save and reopen.
The library keeps every item as a .3dm, so all Rhino object types work. A starter set ships with the plug-in, you can save the current selection as a new item, and the folder is configurable.
Note, this plugin requires Rhino 9
Command name: CrowdControl (toggles the panel).
This looks awesome!
this is good, very good, thanks for putting this together :+1:
Thanks for testing @milezee!
This looks amazing. I’m guessing this won’t ever work on Rhino 8 ?
Thanks! It uses some in viewport UI stuff in v9 so no I don’t think so. Try it in v9 if you can.
I’ll see if my company will update :slight_smile:
Any chance this availible in Grasshopper ?
I’d have to think about how it might work in GH. Honestly, one of the reasons for making this plugin was to replicate GH workflows for users that didn’t want to learn that tool.
Doesn’t Shapemap do exactly this?
Just downloaded it, from pictures it seems to be similar yes. Although Brians work was so crazy intuitive that I would have close to zero issues implementing the possibilities of Crowd control at work.
I have many coworkers who seems to get dizzy when I show them my Grasshopper definitions, sadly.
currently i’m encountering this problem where say i want to map a capsule shape surface on a dome shaped surface, how do i it to flip? e.g- i want the capsule on the convex instead of the concave surface. any idea?
