Crossing curve and infinite vectors to create points
Hi everyone,
I would like to create points at the intersection of a curve and of different lines, however the curve might change so instead of doing very long line to be sure that it will always cross i was wondering if there was a possibility to cross it with infinite vectors?
Thanks in advance,
Regards,
Paul
Intersection>Mathematical>Curve|Line and if your curves are in 3d probably better to use Curve|Plane.
But line aren’t infinite? i will have the same issue as with a curve
the mathematical line is infinite, doesn’t matter how long of a line you input. It really just uses it as a direction.
Ok it works, i was just confused because when you create a line you have to define a length.
Thanks a lot!
