Yes you can. The easiest way is to rightclick on the analysis model component and update the penalty factor. However, this affects every support and coupling. If only specific supports/hinges should be adapted, you have to make changes in the text file. If only one type of support /hinge is affected, you may do this by changing the penalty factor of the respective property. If you want to change only specific supports/hinges, you have to add an additional property with adapted penalty factor and exchange the property id in the respective DE-BREP-NURBS lines (see also this thread: Point support moves - #8 by laura.sophie)
