I would like to customize the _Mirror command (in a C++ plug-in).
Is there a way to reuse the plane picking part ?
Thanks,
Jean
Thanks,
Jean
What part of the plane picking part of the Mirror command is interesting to you. I believe the plane picker is just a CRhinoGetXform-derived class that dynamically draws the mirror objects.
Perhaps I need more information…
What I aim is quite the same behavior than Rhino _Mirror command except that:
So, the whole plane picking may be interesting to me (default picking, 3Points picking and axes options). But I’m more interested in 3Points picking (as the others look easier to implement).
Let me know if this helps or not.
https://github.com/mcneel/Rhino5Samples_CPP/blob/master/SampleCommands/cmdSampleMirror.cpp
Yes, it does. I’ll adapt it because:
But the plane picking is quite clear now.
Thanks very much, Dale.
