I have a need to create a tube with a tight bend radius. Rhino performs this construct but the tube created folds over itself on the inside radius. I want to eliminate this fold and trim at the tube where it intersects itself. Does anyone have a technique for either constructing the tube without the fold or trimming off the fold after construction.
Also a wish for R6 - the automated creation of an irregular closed object centerline.
This might not always be possible, but it works; perfectly smooth, no self-intersecting surfaces, relatively simple modeling.
I used a narrow parabola for this example (red); it’s a pretty small curve, and a relatively large diameter cylindrical surface (green) smoothly navigating the sharp curve. The solution; Sweep 1 with the small radius curve on the inside and the circle (electric blue) on the outside.
Depending on the accuracy you need, this technique is very simple and fast.
I show points, select the ones that overlaps, start MoveUVN and move the “Smoothing - U” slider to the right as much as needed.
You’ll find the before/after in the attached file. SmoothPipe.3dm (687.2 KB)
