I’ve managed to make these 2 surfaces, i want to extrude the top surface to the bottom surface to create a chamfered solid. can anybody tell me what to do here?
Hi Foot - depending on exactly how things are arranged, you may be able to simply Loft
between the edges, Join
, and then ChamferEdge
if needed. But getting that loft in there cleanly might be tricky depending on how the edges are - can you post the surfaces?
