Creating Rhino Command using Python
I am trying to create an RHI installer file for my python command in Rhino.
Following the guidelines on the attached link, the created installer File alwas results in an error: “An unexpected error occured”.
The two files that I zip and rename to SelectStl_Lines.rhi are both in the dev folder of my command as described. Here is the code of my plugin.py:
id="{eb37d9f0-b34b-4701-b501-d8c7bfa677b2}"
version=“1.0.0.1”
title=“SelectStl_Lines”
And SelectStl_Lines_cmd.py is my python command
Thanks for helping me finding the Bug!
@will, is this anything you know about?
Hey @l.fuhrimann, would you mind send me a copy of the .rhi file so I can look into why it’s not working? Also, which version of Rhino are you using?
Sure, attached is the .rhi file created. I am using Rhino 5.0. Thanks for your help!
SelectStl_Lines.rhi (1014 Bytes)
The .rhi package shouldn’t contain the dev folder. The __plugin__.py file and any command files need to be in the root of the .rhi package.
Works like a charm now thanks a lot!
