I find the way creating polygon but i couldn’t repeat that in different center points. at firs i create plane then circle then polygon. when i write this"Plane=rg.Plane.WorldXY.Origin(Point)"
the massage is “Point3D is not callable” please let me know the correct one.
This doesn’t work:
– plane.Origin is a property of the plane, not a method that you can input a point argument. You need to set the origin point after the plane instance is created. Try this instead:
plane=rg.Plane.WorldXY
plane.Origin=point
great., Thank you for your responding.
