I need some help ^^. I am working on a C++ plugin for Rhino 5.0 to generate a surface from 4 arcs that I create from the principal curvatures of another surface. The main idea is to use this 4 arcs as the surface edges and the inteception of them as the surface vertex. However, I have not found yet any information on how to create the surface using the edges and vertex.
Hi Dale,
Thank you for your reply. Take as an example the image below. On C++ I was able to create the 4 curves that define the surface’s edges (those curves are saved on a ON_ClassArray). Also, with them I was able to create the vertex (points). Now, using Rhino commands the next step would be to use “NetworSrf” , select the four curves and set the tolerances to 1 (in order to make it as simpliest as possible). The idea is to get the same surface using C++ code.
Hi all! I managed to create a surface using the CreateCubicLoft() method from the ON_Surface class. However the result is as shown below. Any ideas on how specify the curves order? is that my problem?
Thanks
Andres Uribe
