Creating Multiple Rings in Panther
Im trying to create two separate rings but need to create them in the same model space. Is there a way to do this in Panther? Each time I try to draw another ring shank, it just edits the first one. Thanks! Have attached a PDF to illustrate what I mean if this is not clear.View_A
Hi Suzi, thanks for your message. From your description, it looks like you are creating a new ring on the same position of the first one, we could confirm if you provide a screenshot.
Please note each ring builder will load the ring on the center so you will need to move it after adding to the document, just select it and use the Gumball arrow to move the matching band:
