I was wondering if there was a way to create lines perpendicular to a set of points without having to create individual line components by defining start and end points. I am trying to create lines similar to the manner I have it drawn below (with each color representing a group of lines between points).
One way I can achieve this is by doing the following.
Which produces the following results.
However, the trick is that the number of bays (defined by the lettered gridlines) can change based upon user-input. So, if an additional bay is added, I would have to manually add additional outputs to my “explode tree” component and additional line components. This becomes very tedious especially if the user wishes to adjust the number of bays rapidly. Is there another way that I could streamline this process without having to manually create these line segments?
See attached for my script. Thank you!
01-SAP-Model-Steel Design.gh (86.5 KB)
