hi guys, im really new to grasshopper and im trying to connect the 2 layers of voronoi together at areas where the two layers of curves crosses with one another by creating a support, i watched a few tutorials on youtube but im not sure if the way i should be doing it is through using interpolate?
Hey!
Would you upload your grasshopper file ?
Although I think by exploding both curves and then finding the middle points with some data management, the problem will be solved, but I highly recommend you to upload your grasshopper file with internalized points too.
ah yes thank you so much!
