I need to be able to trim or sculpt several sides of a free-form subD object into flat planes, as I’ve attempted to sketch in the image below. Ideas welcome. I need to retain the closed subd editability through the life of the object. (A trim command turns the subd into a polysurface. )
You can achieve it via the BooleanIntersection with History recording enabled. Please note that when running BooleanIntersection, make sure the DeleteInput=No option is checked. I made a clip for your reference.
Thankyou very much Jessesen.
Actually Jesessen, now that I’ve actually tried this, the result isn’t a subd, it’s a polysurface. Looking for way to maintain a subd.
