I am setting up a deployment for Rhino for my company and have been poking around in the Rhino& appdata folder and settings files trying to determine a way to set the default units to Feet and inches at the time the program is installed. Is there a settings file where I can make this change. Having the program start up automatically for users in Millimeters is not going to work. I would also like to make default to Feet and inches at install, to avoid having to rely on users to set the default template themselves.
Hello- - without a templates file, Rhino starts with mm. If you want Rhino to open with a different template, you can set a default template fie - that is set in OPtions > Files page or in using the New command and setting the template you choose as the default. Note you can make your own template files (SaveAsTemplate
) The template file path is stored in
“C:\Users\USER_NAMEAppData\Roaming\McNeel\Rhinoceros\7.0\settings\settings-Scheme__Default.xml”
e.g.
C:\Users\USER_NAME\AppData\Roaming\McNeel\Rhinoceros\7.0\Localization\en-US\Template Files\Small Objects - Millimeters.3dm
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/saveastemplate.htm?
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#options/files.htm?
