I have an excel spreadsheet which I am trying to create wireframe using VBA. Lines and arcs I have successfully done, as well as reading the ordinates of a curve into the spreadsheet. This spreadsheet does a lot of analysis for us so this is the preferred method, rather than having the automation as a rhino script. Below is the vba code I have written to create the curve, but when it does the addcurve call I get a run-time error 10 about an array being fixed or temporarily locked. Any ideas anybody?
Sub RhinoCreateCurve()
Dim Rh As Object
Dim RhScr As Object
Dim SelObject As Variant
Dim NumPoints As Integer
Dim CurPoint() As Variant
Dim XYZ() As Variant
Set Rh = CreateObject("Rhino5.Interface")
Set RhScr = Rh.GetScriptObject()
NumPoints = Sheets("Sheet1").Cells(1, 5).Value
ReDim CurPoint(NumPoints - 1)
ReDim CurPoint(NumPoints)
ReDim XYZ(2)
For i = 1 To NumPoints
XYZ(0) = Sheets("Sheet1").Cells(i, 6).Value
XYZ(1) = Sheets("Sheet1").Cells(i, 7).Value
XYZ(2) = Sheets("Sheet1").Cells(i, 8).Value
CurPoint(i - 1) = XYZ
Next i
RhScr.AddCurve CurPoint
End Sub
