Hi!
Was hoping to create bracing from grasshopper with Rhino inside Revit. The create beam node only seem to create structural framing with structural type=beam. Any way to change this to a structural type=brace?
Thanks
Patrik
Hi!
Thanks
Patrik
Welcome to the community @patrik1!
I added Bracing to the list of new components that we need to create:
Awesome, thanks!
Hi! I don’t know if I should post this in Github rather than here, but I would strongly advise to expose structural type as a parameter in an “Add Framing” component (as you mention at the end of the issue) instead of adding components for different types. I think it better reflects Revit’s way of thinking and also helps avoiding cluttering in RiR components for Grasshopper.
Just my two cents. As always, thanks for the hard work.
