We wanted to provide a feed back from the team on both the Script provided by Japhy and best step recommendations for new assemblies provided by Scott.
We ran the script on our side per your instructions and it worked like a charm for our needs. We can import the Rhino native files back into CATIA with our license converter
On new assemblies, we can have the users define blocks and save out as promoted per the instructions.
Thanks again for helping us with a time consuming issue that was impacting our user community.
We had a reqeust if the script could be modified to grab sub-layers? My rhino team is building sub-layers like an Assy model but the script only pulls the first layer out? Can Japhy adapt?
We gave it a try and see the same results where it’s extracting just the top layer. We are adding a file for you to review with our sub-layer example if this helps adjust the code to make a sub-layer extract tool.Link to Zip File Example
