Hello all,
Thank you in advance for your help! I’m new to Grasshopper and am trying to create a model of a gridshell structure with an irregular mesh, but am falling at the first hurdle.
I would like to create the irregular grid below in plane before rotating and cutting to size. It seems like it should be fairly straightforward but I don’t know where to start to model this pattern of lines - should I be using domains?
I think the first four parameters I should be starting with is the narrow and large spacings, the number of lines bunched together and the number spaced apart.
Any advice will be gratefully received!
