Creating an awning style edge?
Hi all
I’m in the middle of making a band stand cover for a mobile band stand that goes to special motor racing events. The customer wants the edge of the skirt to be wavy like an awning and i’m a moron so struggling with it hehe.
I have been trying to array circles around the skirt edge and then trim but wondering what easier ways there are to do this ?
The skirt is around 250mm deep but could be 300mm if needed and I would like the wave to be evenly distributed, if I was doing this by hand I would make a plywood template with 2 or 3 waves to mark the fabric with
Post a file helps
Hello - you can set a cplane to the vertical edge and then draw a control point curve - Divide on the upper and lower lines will give you points to snap to.
Hiya
Thank you @pascal, It seems I wasn’t a million miles away but your way is better than my effort :slight_smile:
Richard
oops spoke too soon,
it works great until you get to a corner and the curve tries to skip the corner
Top View
Hello - if you overshoot as I did with a couple of extra points at each end, you can then trim the curve and have it end on the verticals.
awningPG.3dm (52.2 KB)
hiya
Phew that took some time I can tell you :slight_smile:
What I ended up doing is extending the construction lines past the corner on both sides, then made the Control point curve. both curves intersected almost exactly on the corners so I went around and trimmed the ends off…
Thanks for the tips @pascal , as always you Da Man !! :slight_smile:
