Creating a Wire
I am trying to create a wire (forestay) for a sailboat and I am running into an issue. When I twist the component if I do too little of a degree angle it does not twist and if I do too much it distorts. The twist does not stay symmetrical with the base curve. Do I need to use another command instead of twist?
Thank you,
Danielle
you can edit the component a bit:
alternatively edit the length of axis:
Thank you for your help.
Ok, I got that part. Now, as I stretch the line it stretches the twists. Just like in your screenshots. How do I choose how many twists there are? Mine says it ran Twist component 5 times. Is there a way to condense the twists like in your first screenshot?
