Creating a Weave Pattern
Hi, I am creating a Celtic Braid Bail that I’d like to change the weave design to make the braids go completely over and under each other, however using Sweep1 I have created a design that goes more through itself. While building this I had a few issues with the design flipping and staying aligned to the curve.
Please let me know if you have any suggestions on how to make this a more dynamic design with clearer separation in the weave!
design it planar (left) in WorldXY
then sweep1 will do the job with Rail-like 0,0,1
then flowAlongSrf
→ to the right
there are other workflows, directly in 3d, using sweep2.
but it will be tricky to get the 2 rails with same curve/nurbs structure.
there might be a nice workflow using a fin surface and use the edges for the sweep2 as rails.
post some data that shows what did not fit to your needs.
kind regards -tom
