Hello everyone,
I am trying to project a geometry onto a surface, create a three dimensional volume from it and then cut the volume from the original solid.
So far i have projected a letter on a surface, used offset to create a nother one and used ruled surface to create a surface between the outline of the outher surfaces. Now i want to create a solid so i can use the function “solid trim”. My problem is i can’t create a solid with either boundary surfaces or solid union. I’m slowly running out of ideas on what I can improve, I’ve already checked and adjusted the orientation of the nominal vectors (pointing outwards), I’m 99 percent sure that the three surfaces create a volume so that should not be the issue. Maybe one of you has another idea.
Thanks in advanced
Creating a solid.3dm (849.4 KB)
Creating a solid.gh (20.7 KB)
