Creating a raycaster to visualize view
I’m trying to have a dynamic raycaster to visualize to the view based on a point and direction.
I have a floorplan that is a group of curves. Then I have a point, direction, and view angle. My thought was to have a collection of lines that i could use to intersect the floor plan and the cull them to the shortest lengths, but I cannot get that to work for 2 sets of intersecting objects. Does anyone have an idea for how to do with in grasshopper?
I have it working on 1 crv intersecting 1 crv
I also got it to work with multi crvs intersecting 1 crv, but i cannot get multi to multi
you mean like this?
depending on which intersect input you graft, you will get data sorted in different ways, probably the following is more useful:
[edit]
to fully answer your question -hopefully-
intersect.gh (18.2 KB)
you can end each ray as soon as it touches the very first line on its path by bypassing the reverse list component:
This is it! Thanks. I’ll be studying this for a while.
I was able to take your file and work it into what I was looking for. I added a little vector object I can move and rotate around the model and quickly see the result. Here’s the result. :smiley:
intersectRays.gh (16.1 KB)
Use isovist ray
intersectRays_re.gh (10.6 KB)
