Creating a Hilex on a Truncated cone
Hi, Can some assist with creating a Hilex on a Truncated cone so that I can create a thread.
Once this is done, how do you 2-D scale the truncated cone so that you can Boolean this before using fillet edge.
Hi Abel - use the Spiral command for this- it can make a helix with different starting and ending radii.
Try the Scale2D command from a center Osnap at the base of the cone.
Thank you
