Creating a Closed Brep from an Extruded Surface with Contour Adjustment
I use Image Sampler to convert an “image” from a surface. I then cut out the contour to remove the background. Now I want to create a closed Brep from the resulting surface. To do this, I simply extrude it. My problem is that the back has a negative curvature towards the inside, which I would like to remove. My original idea was to cut out the surface from the base surface using the contour and then join the two surfaces together, but there are openings that I can’t get rid of properly.
Does anyone have any ideas for an alternative solution?
Creating a closed brep.gh (27.9 KB)
Best regards Tim
