In the New in V9 toolbar, I see Create template layers.
Seems it’s not known.
The question is also what this command should do.
Create a drawing or a layer?
Hi Charles -
You’ll need to reset the toolbars to clear that up.
As the command doesn’t create a drawing, the command name was changed to CreateClippingDrawingTemplate. It creates template layers for clipping drawings.
Worked, thanks.
