CreateSolid on ver.2.0
I am using Rhinoceros ver.2.0. I found a command “CreateSolid” on the web. But my Rhinoceros does not accept this command. What version does the Rhinoceros have “CreateSolid” ?
Is there a way to do the same with my ver.2.0 ?
No. Maybe you should consider updating.
if you are on a budget you dont need that command at all. i really in my entire Rhino life only experimented with this command but never had any practical use for it.
Thank you for your advice. I will try the Free evaluation version before purchasing. Ver.2.0 does not have other command that I need such as “FlowAlongSrf”.
Thank you for your quick reply.
