Hi all. Rhino5 last release . If i would like to select in the active document one curve, then delete it and rebuild what should i have to do?
var gx = new Rhino.Input.Custom.GetObject();
gx.SetCommandPrompt("Select one curve");
gx.GeometryFilter = Rhino.DocObjects.ObjectType.Curve;
gx.GetMultiple(1, 1);
if (gx.CommandResult() != Rhino.Commands.Result.Success..
for (int i = 0; i < gx.ObjectCount; i++)
//retrieving nurb
var curve_objref = ...
var curve_id = ....
var curve_rhobj =.....
var nurb = curve_rhobj.Geometry as Rhino.Geometry.NurbsCurve;
// 1)question: is the following control necessary?
if(nurb ==null)
var curve = curve_rhobj.Geometry as Rhino.Geometry.Curve;
nurb = curve.ToNurbsCurve();
//deleting id
Rhino.RhinoDoc.ActiveDoc.Objects.Delete(curve_id, true);
//2) question :how to build it again as it was before????
( Obviously i would like to build it by reconstructing it with interpolated curve or control point curve not with a simple doc.Objects.AddCurve(nurb) )
