Hello
There is a Curve’s method called CreateFilletCornersCurve, that requires 2 tolerance inputs: double tolerance, double angleTolerance. I tried to understand both, so there are two questions:
- I can see a difference while I change the tolerance value, but I can’t see it for an angle tolerance - look here at the GH script to try it: CreateFilletCornersCurve.gh (5.9 KB)
Can you show me the example when it affects the fillet result? - There is a note in the documentation: “When in doubt, use the document’s model space angle tolerance.”. The question is: which one? ModelAngleToleranceRadians or ModelAngleToleranceDegrees?
