I have a Brep pair where the subtractor overlaps the main solid in three disjoint regions. In Rhino 8, Brep.CreateBooleanDifference removes two of them and silently ignores the largest one — and reports no failure. It returns a single closed, valid Brep with no exception, so from the API there is nothing to distinguish this from a correct result.
The same call, on the same file, at the same tolerance, is correct in Rhino 7.
- Rhino 8.33.26188.13001 — removes 1,968.645 mm³ of 33,355.662 mm³
- Rhino 7.38 — removes 33,355.108 mm³
Windows 11 (10.0.26200), 64-bit. Model units mm, absolute tolerance 0.001, angle tolerance 1.0°.
The file
03_GS02_R8.3dm (attached) contains exactly two Breps, saved straight out of my plugin immediately before the boolean call:
03_GS02_R8.3dm (621.9 KB)
| Object name | Faces | IsSolid | IsValid | Volume |
MAIN_GS02 |
110 | true | true | 2,349,059.275 mm³ |
SUB_0 |
8 | true | true | — |
MAIN_GS02 is an extruded aluminium transom profile, SUB_0 is the subtractor that notches it where a mullion crosses.
What the two solids share
CreateBooleanIntersection at tolerance 0.01 gives three separate lumps:
| Piece | Volume | Size (mm) | Z range | Removed by Rhino 8? |
| 0 | 31,386.902 mm³ | 50.94 × 155.80 × 37.00 | 3828.83 – 3865.83 | no |
| 1 | 1,966.664 mm³ | 40.67 × 15.35 × 13.67 | 3852.16 – 3865.83 | yes |
| 2 | 2.097 mm³ | 39.92 × 6.33 × 0.44 | 3865.39 – 3865.83 | yes |
| 33,355.662 mm³ |
Rhino 8 removes 1,968.645 mm³, which is pieces 1 + 2 (1,968.761) to within boolean noise. Piece 0 — a 51 × 156 × 37 mm notch, the largest of the three by a factor of sixteen — is left completely untouched. This is not a sliver or a tolerance-scale artifact; it is a whole notch that never gets cut.
Reproduce
import scriptcontext as sc
from Rhino.Geometry import Brep, VolumeMassProperties
def by_name(name):
for o in sc.doc.Objects:
if o.Attributes.Name == name:
return o.Geometry
return None
main = by_name("MAIN_GS02")
sub = by_name("SUB_0")
tol = sc.doc.ModelAbsoluteTolerance # 0.001
def total_volume(breps):
t = 0.0
for b in breps:
t += VolumeMassProperties.Compute(b).Volume
return t
res = Brep.CreateBooleanDifference([main], [sub], tol)
print("returned: %d brep(s), faces=%d" % (len(res), res[0].Faces.Count))
print("removed : %.3f mm3" % (VolumeMassProperties.Compute(main).Volume - total_volume(res)))
# how much SHOULD be removed - the shared volume, as separate lumps
inter = Brep.CreateBooleanIntersection([main], [sub], 0.01)
print("expected: %.3f mm3 in %d piece(s)" % (total_volume(inter), len(inter)))
for b in inter:
print(" piece: %10.3f mm3" % VolumeMassProperties.Compute(b).Volume)
Rhino 8 prints:
returned: 1 brep(s), faces=116
removed : 1968.645 mm3
expected: 33355.662 mm3 in 3 piece(s)
piece: 31386.902 mm3
piece: 1966.664 mm3
piece: 2.097 mm3
Rhino 7 prints 1 brep(s), faces=118 and removed: 33355.108 mm3.
Tolerance sweep (Rhino 8)
| Tolerance | Intersection.BrepBrep curves |
CreateBooleanDifference |
Volume removed |
| 1e-6 | 7 | null |
| 1e-5 | 6 | null |
| 1e-4 | 7 | null |
| 0.0005 | 8 | 1 brep, 116 faces | 1,968.800 |
| 0.001 (doc) | 8 | 1 brep, 116 faces | 1,968.645 |
| 0.002 | 8 | 1 brep, 116 faces | 1,968.529 |
| 0.005 | 6 | 1 brep, 116 faces | 1,968.800 |
| 0.01 | 7 | 1 brep, 119 faces | 33,346.864 |
| 0.05 | 7 | 1 brep, 119 faces | 33,334.772 |
| 0.1 | 12 | 1 brep, 116 faces | 33,335.600 |
| 0.5 | 9 | 1 brep, 119 faces | 33,334.772 |
Two things I found odd:
- There is a band from roughly 0.0005 to 0.005 where the result is silently wrong, and it straddles the document tolerance. Below 1e-4 the call fails outright (
null); from 0.01 up it is correct. - The overlap curve count from
Intersection.BrepBrepis not monotonic in tolerance — 7, 6, 7, 8, 8, 8, 6, 7, 7, 12, 9. At the document tolerance it reports 9 curves in Rhino 7 and 8 in Rhino 8 for this pair. The missing curve looks like the trim loop bounding piece 0.
Also worth noting: Brep.CreateBooleanIntersection(main, sub, 0.001) returns null in Rhino 8 — the intersection fails outright at exactly the tolerance where the difference silently succeeds with a wrong answer.
Already ruled out
- Distance from origin. The geometry sits ~414,000 mm out, so this was my first suspect. Translating both Breps ~414,000 mm toward the origin and repeating gives identical curve counts. Not the trigger.
- Invalid input. Both Breps report
IsValidandIsSolidtrue. - Different inputs between the two versions. Both were written to disk by the same instrumentation immediately before the call. Same face counts, same volume to three decimals, same bounding box.
- Different code path. One source tree, no conditional compilation anywhere in the modeling code; only the target framework (net48 / net8.0-windows) and the RhinoCommon package version differ.
Why I am reporting this rather than working around it
I am migrating a curtain-wall plugin from Rhino 7 to Rhino 8. These booleans feed fabrication drawings and NC hole data.
A boolean that fails is recoverable — I already retry at increasing tolerances, and have done since the early days. A boolean that returns a clean, valid, wrong solid is not something the caller can detect, short of computing the expected shared volume for every operation and comparing. That roughly doubles the cost of a step that runs thousands of times per model, so it is not a practical guard.
Until this is sorted I cannot trust Rhino 8 output for production work, which is a shame because the rest of the migration has gone smoothly.
Is this a known regression? Happy to provide more files — I have the matching capture from the Rhino 7 run, and can dump other joints from the same model if that would help narrow it down.
Thanks,
