If I have a block containing multiple VA objects, such as curtain walls, and I apply the “CreateUniqueBlock” command to that block, all the VA objects inside the newly created block convert from VA objects to regular Rhino blocks.
Has anyone else been able to reproduce this issue?
Hi @fsalla another odd thing,
Is seems to me that Rhino slows down considerably when VA objects are inside blocks?
Sharing attached a simple model with VA objects inside blocks, if you explode everything until it is polysurfaces, or explode only the VA objects inside the blocks, everything speeds up again.
The exploded model is faster in my experience, very odd.
Hi @lourencovp thanks for reporting this problem. I can see that this model runs slower when VisualARQ is loaded. We will investigate what’s causing this and try to improve it. I’ll keep you posted with any progress.
