Create surface problem
Hi
I am Johnny. I use Rhino 5. The problem is i made 2 curves ( i drawing guitar) and then i use loft or tsSkin or D.Loft the result is same the surface not following the curves just creating polygon surface. I upload the picture juust see the problem
Please help what the problem!
Sorry my english a little bit bad
Cheers
Johnny
Hi
You are seeing the effects of coarse mesh settings because you’re in a shaded display mode:
Have a look at these FAQs:
http://www.hydraulicdesign.net/meshes.htm
http://wiki.mcneel.com/rhino/meshfaq
Hi
Thanx to the answer i think now its ok. I change the mesh properties
