I am trying to create a panel with perforation on it. I got the circles on the panel but how do I make them stagger between rows?
There are a few approaches that you could take. One direct approach, might be to map a hexagonal grid to the surface, then create your circles in the hex grid cells. There are plug-ins that make do this as well, but here is a simple example with native components.
could you please upload the file?
I tried to re-produce the definition in the picture but I’m missing something
Bounding Box --> Union Box
Here is the file. As I mentioned, there are probably many ways to do this, this is just a simple example.
HexGridMap_GH_R6.gh (12.8 KB)
Where can I plug that map in on this map? I can control the distance between the circles with this one, so I just don’t know where to put the hex grid or what to do
Could you add a sketch of what the desired result should be?
You can also upload the .gh file here so that whoever wants to help you don’t have to recreate your definition.
I would like to create a surface with this pattern in it. I have it done a pattern in the .gh file below without the circles being staggered, just don’t know what to change in order to create the staggered circles. I need the circles to be .188" apart and .094 circle diameter…
CPP1 7-15.gh (24.6 KB)
