I have a user who found what seems to be a bug, where creating a sphere in space creates a bad object. I updated to the latest SR to see if the problem replicates and it does. The problem:
If I create a sphere at the origin (file is in millimeters) with a radius of 50,000 - then a normal sphere is created. It is a good object.
But if I create a sphere in space, then the object that is created looks fine, however it is a bad object because it cannot be edited or transformed. When running the SelBadObjects command, it selects the sphere created in space. This is true on the user’s machine, as well as my own computer, so this seems to be an issue across Rhino. This “bug” persists on SR 7.14 as well as the latest SR 7.17
Just to recap the steps:
draw a sphere at origin = good object created
draw a sphere at point indicated in the file (radius = 50,000) = sphere is created as bad object
SelBadObjects - will select the sphere created at the point in space. Sphere cannot be edited or transformed
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 31Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-3-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.53
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-3-2021
Driver Version: 27.21.14.6253
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\Beam\App\MKS\bin\RHINOBEAM.dll “MKS BEAM” 1.6.3.1
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21349.1646
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.6.8014.23580
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
