I’m trying to Boolean Union those 2 surfaces to create 1 solid surface. It doesn’t work, maybe because 1 surface is open ?
For mcneel.3dm (1.1 MB)
Thanks! Well, if i have two closed surfaces overlapping each other, won’t the 3d printer count them as 1 solid anyway ? Or maybe i can use somethin like Meshmix to make 1 solid surface ? What strategy do you suggest ?
Depends on the slicer.
shrinkwrap is your best friend when prepping parts for 3d printing.
Yes and no, I’ve encountered some surfaces so poorly modeled that shrinkwrap exploded the mesh in a weird way.
Managed to get around it by offsetting the mesh and using close holes, but lost a lot of detail in the process.
if you have overlapping solids, yes, most slicers will process the overlapping solids as a single object. in fact this is usually far easier and more reliable than trying to make one single polysurface if you are working with any remotely complex forms.
in addition, not all slicers process internal voids. the example in the file below shows an internal void where the purple volume is created by the adjacency of all the red volumes and is entirely contained between the red volumes.
solids and voids.3dm (303.7 KB)
if you export just the red volumes, some slicers will process this configuration as a single solid (eg: chitubox, zcorp slicer) and print the overall box with infill in both the purple and red volumes. some slicers will only process the red solids (eg: prusaslicer) and print support material in the purple volume.
for what looks like a shoe, it shouldn’t be a big deal, but in other models it might be significant, so see what your slicer does
What about Meshmixer ? Can i create 1 solid there before sending it to a slicer ?
shrinkwrap is a nice tool but its not a universal remedy.
when the meshes/surfaces are not closed and the gaps too big you have to inflate the vertices cps instead which drastically deforms the entire geometry. specifically in this model i tried that to begin with, because it is oh so inviting but hell no that did not work here.
rather put some effort into fixing it instead
i’ve not used meshmixer in my process for printing. as long as you:
then the files are usually printable.
there are some weird moments in meshing offset surfaces like this:
but cross that bridge if you get to it.
