Hi guys,
I tried to make a surface bridging which is similar to the wormhole, but I don’t know how to apply in the organic form…
[Test1]
[Surface bridging]
Is there any suggestion?
Hi guys,
at best, I would try sending a 3DM file. otherwise, it will be quite difficult for anyone to give an accurate answer…
I would like the make an organic form with three wormholes in the form. After I used blendSrf and transformed the open polysurface to a mesh, the mesh is not smooth enough, like below image.
I would like to create holes like this one, smoothly connect to the surface!
(( This smooth one is created by me, I used Torus and reshape it,but it only has one hole))
Organic_Form.3dm (1.1 MB)
BlendSrf and transformed the open polysurface to a mesh , mesh is not smooth enough…Some weird lines appear.
Organic_Form_Blend_BlendSrf_Mesh.3dm (5.8 MB)
Anyway, Thank you very much for your reply, it means a lot to me!!!
The Rhino meshes won’t give you nicer results. In v7 there will be an improved QuadMesh tool that will give you a mesh consisting of quads, but until then you won’t be able to get the same as from a torus.
Hello - it looks to me like the holes in the outer surface need to be both more circular and larger to get the effect you want with no self intersection.
Organic_Form_Blend_BlendSrf_Mesh_PG.3dm (382.9 KB)
@yoyolau19951024 V5 now
