Create smooth indented surface (like image attached)
I’m trying to make a surface that mimics this eye shadow palette. I’ve tried patch after extracting points, draping, and lofting contour topo lines but I can’t get anything this precise. Any suggestions are welcome! Thanks
Screenshot 2023-08-17 at 11.53.52 AM (1)
Have you tried displacement?
Look at this video of @BrianJ
you can aso draw the center curves of the waves then offset both sides, trim the inner parts and sweep2 with a curve which you created by blend curve. for a smoother result use quadremesh, then you have the option to use the command smooth for a finer transition.
