I am trying to add Rooflight, using the plane
as Location then I try to rotate. I am placing family and then set two-parameters width
and height
. So here my steps:
- when I have 0deg all seems to be correct
just I can see two items here and some warning on host node:
1. This object was expired because it contained obsolete Revit elements.
is this correct? or I should flatten list to have one element…not sure how to do it…
- When I try to rotate pane by 15deg it shows me rotated correct on preview but insert same as 0deg
when I make 90deg, seems correct just same warning on host
when I make 225 deg it make 90deg but in preview shows correct value
any advice on how to eliminate warning on the host and why I can not make rotation like 15, 45, 225 etc.,.?
