It appears the Create Shaft user object is broken because External.DB.Extensions.CurveExtension.ToCurveArray is no longer valid. Was this function moved to another part of the API or is there a better way to create a CurveArray for use to create a shaft opening?
Hi Stephan,
Opening Components were recently added
https://www.rhino3d.com/inside/revit/1.0/reference/release-notes#v1-6-rc1
Here’s the current documentation for the CurveArray if you are rolling your own. GeometryEncoder.ToCurveArray Method
