Create Points on Mesh
@pascal - Works perfectly. Thank you so much for helping me on this! I really appreciate it!
-mcmucher
OK, youā€™re welcome - good, Iā€™m glad that works. I updated above to include a "resetā€™ option, that was bugging me.
Hi @pascal ,
Iā€™ve encountered one issue with the script.
When I select a point list, everything works fine. I can stop and restart where i left off and I have no issues.
Without closing Rhino, if I change the list, an issue arises. If I stop and start with the second list, the FIRST list becomes the current list, rather than the one I was just using. Do you think thereā€™s anyway to get it so it doesnā€™t revert to the original list used?
Thanks!
mcmucher
Iā€™ll take a lookā€¦ prolly doing something dumbā€¦
@mcmucher - please check the file in the post above, I refreshed with a ā€˜fixā€™. Let me knowā€¦
I somehow missed this updateā€¦but I think you fixed it!
Thank you so much!
-mcmucher
Hi @pascal, Iā€™m actually continuing @mcmucherā€™s work and I had a follow-up question. This might be an obvious answer, but is there any way to display those point names on the mesh rather than just under ā€œNameā€ in the Object properties window? I tried using PetersToolsCommand > DotWithData, but that gave me a dot with the mesh name rather than the point names. Thank you!
Hi Grace - probably easy - can you post or send me an example input file?
Sorry for the delay! Iā€™ve attached a sample file and points list. test_points.txt (60 Bytes)
testarm.3dm (5.4 MB)
Hi Grace - @grace1 see how this works - labels are on by default for now, but you can turn them off at the command line. They can be off by default if that is better.
NamedPointsOnMeshEx.py (3.6 KB)
Thank you Pascal! Thatā€™s awesome :slight_smile:
A post was split to a new topic: Polyline on mesh
