I intend to place all panels on a freeform surface, and each of them should be standard.
However due to the freeform surface, some of the hexagonal cell would appear being stretched and the hexagonal shape is no longer obvious.
I don’t understand why are you mentioning “hexagonal cell” because you are using Lunchbox’s Triangle Panels B. If you want hexagonal pattern, then there is the Hexagon Cells component in Lunchbox plugin.
And if you’d like to get rid of all the none hexagonal cells, you can cull out the cells that have less than 6 discontinuities…
Thanks again HS_Kim!
Recently I want to use Triangle Panels B is because I want it to have those pyramidal vertex on each hexagon panel, eventually each cell comesout forming a hexagon.
But your solution just convinced me that there are another way to achieve it using hexagonal cells. Solved!
