I want to create multiple parts, maximum of 8 using the same definition and these will form a set that is then available to purchase.
Each part is created with the same definition to build up the set by adjusting the parameters for each component.
What’s the best strategy for putting this together, I would guess that the same input parameter boxes are used to run the definition again and agin to complete the set with each added part moved along on the canvas so as not to be on top of each other. These are 2d components.
You can definitely create a definition that creates number of designs depending on parameter set up. Our video tutorial and webinar series cover various techniques how to build online 3D apps efficiently. Check our blog for more.
