Create multiple circles using the 3 point method
Hello dear Grasshopper community,
is it possible to create multiply circles (aprox. >1000) with 3 point method in Grasshopper. I will have a list with coordinates (X, Y, Z).I am thankful for any help!!
Greetings
Alex
Hello - if you have a text file, I think you can just feed the points directly from a file component to a Circle component:
Hi Pascal,
Isn’t that just going to give you circles with the same radius, centred on each point? As opposed to circles through three points?
Something more like this maybe:
Assuming the input file can present triplets of points and not just a continuous stream (the latter being more error prone).
Regards
Jeremy
3ptCircles from file.gh (23.0 KB)
Set the File component to the following file (or another file that is delimited like this one):
Co-ords.csv (54 Bytes)
White group, adapted from a recent post, this uses random points in 3D.
Circle_3pt_2021Oct07a.gh (18.5 KB)
1000 circles gets rather intense!
P.S. I don’t remember why that yellow group looks more complicated than necessary?
Circle_3pt_2021Oct07b.gh (16.4 KB)
Hi Joseph,
I knew there had to be a better way than three clumsy culls - your item component with three outputs is so much more elegant. Thanks!
Jeremy
Just 2 small additions to Joseph’s file
Circle_3pt_bb1.gh (16.0 KB)
Hello dear Guys,
I am very appreciate for your help. Thank you very much!!
