Create Multi-segmented Grid in Revit from multi-segmented curve
Trying to use the “Add grid” component, and it’s asking for a “type” input. I cannot find “multi-segmented grid” as a type under Grids even though I have several multi-segmented grids drawn in my current revit file. And when I tried to get the type from picking the existing multi-segmented grid, it only lets me pick one segment and not the whole thing. I’m at a loss here… something obvious that I’m missing?
Update, I input just a random grid type and it did make a grid for me, after I closed out of the following error message. However, the association between GH and Revit is instantly broken. When I update the curve, it makes a new grid rather than updating the existing grid.
Yup this seems to be a bug. When you supply a multi-segmented curve into this component, the Revit API creates a MultiSegmentedGrid and the component fails sending this to the output. We’ll get it fixed. The grid types between the two are however the same
Has this been fixed? I stil can’t create a multi segmented grid. The input requires a line only.
Hi Attheeast18,
That hasn’t been put into native components. I’ve added a feature request.
Here is a rough scripted version to get you going.
Rh8-RiR-AddMultiGrid.gh (15.7 KB)
Thanks, Japhy. Will give it a try :slight_smile:
‘Add Multi-Grid’ component is now available on v1.22 and will be also on v1.21.
