Create linear / rectangular lights in grasshopper!
Hi all
I am aware that Human has a Light component, but i want to create linear or rectangular lights in gh. Searched through the plugins, and i can’t find anything, maybe there is a way or, maybe someone knows how to iterate this in c# or python.
All help appreciated
thanks
Arkadius
found that there are instances like this:
‘rs.LightDirection’
‘rs.RectangularLightPlane’
in rhinoscriptsyntax, but i am unable to write python to this level.
Hi @arcade.smith,
I’ve tried it inside GHPython and it doesn’t work. It seems as if the lights module is exclusive to Rhino Python (?), meaning that it doesn’t work in Grasshopper.
The scripting part isn’t that difficult though:
# Create two points for the direction of the light
start_pt = rs.AddPoint((0,5,2.5))
end_pt = rs.AddPoint((0,0,0))
# Create the light
rs.AddDirectionalLight(start_pt, end_pt)
Feel free to try it in Rhino Python, as it works there.
Runtime error (MissingMemberException): ‘GrasshopperDocument’ object has no attribute ‘Lights’
Traceback:
line 35, in AddDirectionalLight, “C:\Users***\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\light.py”
line 16, in script
this is the error i get
As mentioned above:
Yes mate, thanks for your help @diff-arch
@arcade.smith have you tried the script in Rhino (not Grasshopper)? It sure works there!
Unfortunately, this means that you probably have to script your idea entirely in Rhino Python.
hi @diff-arch
yes thanks alot
for the meantime this looks like the only workaround,
cheers
Hi guys. If you want to fiddle with the Rhino document from GHPython, you must explicitly set the script context to target the Rhino document. Here’s one approach:
import Rhino as rc
import scriptcontext as sc
# Set context to Rhino document and disable redraw
sc.doc = rc.RhinoDoc.ActiveDoc
rs.EnableRedraw(False)
# Fiddle with the Rhino document
# Set context back to Grasshopper
rs.EnableRedraw(True)
sc.doc = ghdoc
